AOD battery drain S20 fe 5g
(Topic created on: 08-29-2021 08:25 AM)
PupuBaccha
Always on display is draining too much battery on my Samsung Galaxy S20 FE 5G Edition. It cuts upto 10 percent battery during a 8h idle time, thats totally annoying and makes me disable that aod. it requires an immediate action, please have a look anyone who is able to fix this.
12 Comments
AlphaTrion
Samsung does almost everything to cause a small error that can cause minor issues. They wouldn't hesitate to do those.
AlphaTrion
True.
I agree, your 3000 mAh might be terrible at performing.
Do you experience lags in S9 ? If so, during what process ?
AlphaTrion
The lag could be due to 4 GB ram. Otherwise I think it should be performing without lags like S9+, since we got the same processor.
I agree, battery is terrible after updates. Their display is good visually, but its life is too bad, never bothered in fixing it.
Pixel is gonna come with a new processor, with some help from samsung. Hope it performs great.
AlphaTrion
Yeah, definitely OneUI eats more ram than Touchwiz which indicates how heavy it is, no optimisations too.
You are facing lags because of only having 4 GB ram, I think that's a fact as I'm not facing lags with 6 GB, atleast in normal usage. That must be a reason.
AlphaTrion
Yes. When it comes into software, iOS takes the cup. When you compare iOS and OneUI, OneUI has many features and stuff. But its quality is nowhere near iOS.
Samsung is like, they have almost everything, but not perfectly implemented like Apple.
Animations and gestures are one example, both have it, but OneUI is glitchy, it lacks perfection.
Same goes for many other things.
AlphaTrion
That's the worst part, hardware.
Total waste of money.
The snapdragon model is much better, but that also becomes a bad choice since it has a display which can die anytime.
AlphaTrion
Yes. Best to avoid it.
Only knows to flood the market with newer devices, leaving the older ones unfixed with lags, battery drain etc...
AlphaTrion
Yet some people will say "samsung is best" 🤦
Too blind, wasting money.
Yeah, probably samsung is paying them to say it, lmao.
natories
Try on safe mood put ur phn on safe mood at night before u go to sleep
