A Solution For Screen Burn In
(Topic created on: 07-20-2020 12:26 PM)
PurshuRana
Hai, im a Samsung Galaxy S9 Plus user from past 2 Years.
I love my Samsung Galaxy S9 Plus a lot , i love every feature of this mobile especially the Design and Camera. But recently one thing has disappointed me hugely was Screen Burn In.
Yes Screen Burn In is very annoying thing when every u look display. I googled and i came to know about some oled burn in fix apps that are on the playstore with didnt work for me to any extent...
Some said there is no solution for screen burn unless changing the display.
Here is wat i did...
1. Apply Black wallpaer.
2. Enable force dark mode( android 9 and above).
3. Enable dark mode(android 9 +).
4. Maintain brightness at least possible level in all lighting conditions.
5. Maintain above settings for a month and u will notice the screen burn being disappeared gradually.
It worked for me , and im not sure either it is Permant or Temporary.
BEST OF LUCK 👆👍👍👍👍👍
I
8 Comments
sreevijay
great information 👍
Š
Not applicable
🤗 another process are ....don't play any games or do something for long time in high brightness( otherwise that logo can stuck beneath the display in future),, try to change wallpaper once in a week,,if possible turn on blue light filter atleast for 3 minutes every day,, etc ....🙃 and by the way if display burn in issue happened especially in s amoled panal then only method is to change the display..if your display burn in issue solved by that method then you are only lucky person....because i have never seen any s amoled panal recoverd by this .....i have noticed also many people's used useless apps ,rgb colour setup for 8 or 10 hours...but in s amoled panel none of the process can be applicable...it's seems like normal because of diminished rest of good pixels only .....those process only worked for lcd panal......and lcd,tft screen basically don't get display burn in...it's ghost imaging which goes after sometimes 🙂🙂
PurshuRana
for screen retention....do turn on screen saver option available under display settings....
Not applicable
yes ..that is also helpful
PurshuRana
yes lcd and tft wont get screen burn in..only oled displays get
mihir952
thanks for your personal concern.
but what solution is samsung  providing for this rubbish falgship phones that has display brightness problems after new upgrade in 2020 ?
just in 1 year the phone goes out of warranty .
is the flagship phones from samsung are so cheap in quality that is even cheaper than  Mi or oppo basic phoones starting from 8k ?
Members_OIiwzp8
Hi
Are you getting any screen burn issues or its permanently fixed?
