Resolved! Solved
45W charger for S25 ultra
(Topic created on: 02-24-2025 10:06 AM)
RedBrij
Beginner Level 4
Is it recommended to ourchase the 5W charger for s25 ultra?, i am currently using a 25W onenplus charger.
Additionally is the chargjng cable provided wjth my phone, 45 W compatible?
5zaan
Samsung's original 45-watt charger's the best. The cable in the box won't give you the full 45 watts, so get a 45-watt adapter and a 5A cable combo (3500 rupees).
5 Comments
5zaan
PriNcE-Ms
I have a doubt my poco device with 33w charges fast 0-100 in 45mins but Samsung 45w charges 0-100 takes an hour why it is like that
DP1010
I am using 45w samsung adaptor with the inbox cable of s25 ultra, and it is fully capable of charging 2.0 super fast.
goodthings
Kindly use only original Samsung adapter of 45w. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
