07-16-2025 01:01 PM in
Galaxy S- « Previous
- 1
- 2
- Next »
07-16-2025 04:20 PM in
Galaxy S- Mark as New
07-16-2025 06:00 PM in
Galaxy STurn off the shot suggestion.
It will be fixed.
Hope it will help
07-16-2025 05:09 PM in
07-17-2025 08:40 AM in
Galaxy SDear Samsung Member,
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
07-17-2025 10:10 PM in
07-25-2025 10:11 AM in
- « Previous
- 1
- 2
- Next »
