Charger problem
(Topic created on: 10-30-2024 01:43 PM)
GolamRabby
Galaxy On
m21 original charger charging very slow what is the solution?
9 Comments
Galaxy On
Buy new charger duhhh.
goodthings
Galaxy On
Please charge your's device in cool atmosphere also during charging turn off internet then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
GolamRabby
Galaxy On
goodthings
Galaxy On
Your's most welcome.
goodthings
Galaxy On
Your's most welcome to here.
Mayur000
Galaxy On
Do you have a multimeter?
Check the output voltages of the adapter, visit local electrition shop..
If your charger outputs the same voltage then your charger is ok.
So first clarify the output voltages of your charger using a multimeter.
For low voltage, replace any diode, coil and repair charger
GolamRabby
Galaxy On
thanks bro❤
Mayur000
Galaxy On
Welcome
cs_member10
Galaxy On
Dear Samsung Member,
● If you are using a non-genuine Samsung charger, check the device charging by using another Samsung genuine charger. However, we do not recommend using any slow charger for charging Samsung devices. So, Kindly use a genuine Samsung charger for charging your device.
● Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged, then kindly visit your nearest service center to get it replaced.
● Check charger functionality with a different device or try to charge the same device with a different charger.
● If the rating is 15W or above: Kindly try to charge the device in a non-inverter socket.
● If you using a normal socket: As a safety measure Fast charging may not support, you while you are using the device hence, request you to keep the device idle and check the charging performance.
Note: Kindly open Device Care from settings > Battery > Please tap on three dots (more options) at the top right-hand side > Please select settings > Enable fast cable charging.
For Android 11: Kindly open Device Care from settings > tap on Battery > tap on More battery settings > Fast charging > Turn on.
● Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
● Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
● Kindly check if ''Multiple applications'' are running in the background of the device.
● When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
● Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
