technical problem
(Topic created on: 03-03-2017 05:38 PM)
laddu
Galaxy Note
hi I am using Samsung Galaxy Note 4 there is a technical problem from past one week the device UI isn't responding. it's getting hanged all the time.
5 Comments
gayathriR
Galaxy Note
that's normal . that note4 is already outdated and latest applications are not responding to that chipset or reset the device then check ..
GauravK21
Expert Level 3
Galaxy Note
BTW I'm using Note 4 from 1.5 years and I have not noticed any single lag..
I'm also heavy Gamer.
Samsung_India_
Galaxy Note
Thanks for being with Samsung and for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device performance may vary based on multiple outside factors. It appears that there may be a third party app or other program that mayBug be leading to what you are experiencing. Placing your device in safe mode disables all third party apps upon startup, to help determine if the use of a third party app is interfering with your device .restart your phone in safe mode. While your phone is powered off, press the power button to turn on the phone, once you see the Samsung logo appear press the volume down key and hold it until you have completely booted up. Also, the relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
PSG
Galaxy Note
it's time to root your bad boy
laddu
Galaxy Note
I have restarted 100 times its not working at all
do you want me to take it to samsung service centre.
