superfast charging not displaying on note 10 plus since two days
(Topic created on: 01-20-2020 05:00 PM)
raptor
Galaxy Note
It's been 3 days since my phone is showing fast charging instead of superfast charging, Firstly I thought it's just a minor problem as the adapter changes the watts according to requirement.But when I tested my previous 15 watt charger on my note 10 plus ,it shows the same remaining time as my 25 watt charger.I have tried all the things like restarting, reset the settings,toggled the fast charging button on care on and off,tried on other sockets ,started in safe mode but none worked  still displaying the same fast charging instead of superfast charging.#superfastcharging #note10plus not working.Any useful suggestion will be helpful
10 Comments
Galaxy Note
same problem with my note 10 plus too
raptor
Galaxy Note
since when
Not applicable
Galaxy Note
bro it is not about showing it never showed , look in my note 10+ same as before
Not applicable
Galaxy Note
raptor
Galaxy Note
it did showed,that's why wrote in first place. and how will I know if didnt see it..
NiteshMeena
Galaxy Note
which font you are using ?
Not applicable
Galaxy Note
SAMSUNG SANS
Aashish
Expert Level 4
Galaxy Note
It shows that with 45W charger, maybe it did earlier with 25W too but now its removed with update I guess.
raptor
Galaxy Note
it did brother with my 25 watt charger that why I wrote it
