power on issues
(Topic created on: 08-15-2020 04:56 PM)
prasanthpadhi
Galaxy Note
I am currently using note 10 lite from one month and my mobile is running on latest software. Now I am facing a problem when I power on my mobile some weird booting menu is appearing which did not happen in near past. Please suggest is it general software bug or a problem with the device itself?
13 Comments
Ehsank
Galaxy Note
what kind of message on that menu?
prasanthpadhi
Galaxy Note
its something like old menu for factory reset and booting device in older Android devices which seeks us to use power and volume buttons for navigation and selection
Ehsank
Galaxy Note
u can do one thing that reset/format your device.
or better to visit service centre
but if you will reset take backup through smart switch
Not applicable
Galaxy Note
what type of thinks coming? secure startup?
prasanthpadhi
Galaxy Note
Not applicable
Galaxy Note
like this in Normal restart ? why saying because it's factory mode of device ...
Not applicable
Galaxy Note
press this wipe cache partition option then reboot device set by volume up then by pressing power key
Not applicable
Galaxy Note
how it's look like ? secure startup option like ? does it require patter or password to open device after switching on?
Sanskar
Galaxy Note
This boot loader screen ,which appears if we switch device on by pressing volume rocker and power button
