note 9 cam problem
(Topic created on: 02-15-2019 10:30 AM)
DLF
Galaxy Note
The phone starts vibrating when i turn on my rear cam. Why is that happening, is it a software problem or a hardware problem
7 Comments
YRSS
Galaxy Note
report it to Samsung they may help you
DLF
Galaxy Note
hw to report?
YRSS
Galaxy Note
go to Samsung members app and select support and choose option like live chat or feedback.
Zeeshan2
Galaxy Note
oh I see
akshiit
Galaxy Note
samkit102
Galaxy Note
take it to a service center
admin_
Galaxy Note
"Thank you for sharing your concern. Let me recommend some steps to further isolate and determine the issue faced by you in your device. Please be aware that device speeds may vary based on multiple outside factors.
1) Check the Picture size (Camera Capacity) in camera setting (It should be Max according to Camera Capacity)
2) Turn on the Auto Flash (If Available in the Device)
3) Reset the Camera (From the Camera Setting)
4) Software update via FOTA, Kies or SMART Tool.
Be sure to hit ♡ when you find an answer that works for you.
