note 9 battery draining.
(Topic created on: 01-24-2019 11:48 AM)
atharva007
Galaxy Note
Does anyone have a solution for the battery issue after the pie upadte for Note9.
5 Comments
Thuwa
Galaxy Note
ya had same issues then did a full factory reset after that works fine👍
Manikans25
Galaxy Note
if we do full factory reset, is it required to do download the os again l?
DineshManohar
Galaxy Note
no
shubham264
Beginner Level 3
Galaxy Note
me too having same issue after pie...
did 3 times factory reset but still the device is overheating and battery is draining very fast
admin_
Galaxy Note
Thank you for being a part of Samsung community. We apologize for the inconvenience you are facing battery issue in the device after the update. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback via Samsung member application i.e. Samsung member BETA app> BETA feedback>Send feedback>Error report>Collect log files>attach.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
