note 8 samusung problem
(Topic created on: 01-27-2018 03:15 PM)
RKBH
Galaxy Note
There is a problem in samsung music. If a song is searched a list is shown of the songs which matches the search criteria. Then if a user selects a song and it is played, after the song is finished only that songs are played which were shown in the search results. They get played again and again for eg if i search for a song which starts from AB and i search the name from AB and only 10 results are shown so these 10 songs become a kind of playlist. If a user tries to change a song. Then only these songs which were in result area will be played only again I.E if you have total 100 songs and in your ALL SONGS TAB and after you search only 10 songs matches your search criteria, then only those will be played unless you choose the songs from All songs tab again. So pls look in the matter and try to fix it with an update.
2 Comments
s01gautam
Galaxy Note
Download Databuddy App and get Paytm cash upto Rs. 106. Click https://databuddy.co/i/?id=2816618
admin_
Galaxy Note
Thanks for being with Samsung and sharing your concern. We would like to inform you that when you want to search any song and type the keywords it will pick the keywords and show the search result accordingly. There is a option of sequence of songs then you can select the type of sequence according to your need like Suffle , Single , Loop Etc. Once you will select the sequence type it will play songs according to the sequence from all songs that you have in tab. Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
