note 20 ultra battery backup
(Topic created on: 03-06-2021 08:14 PM)
prakharg
Galaxy Note
I seriously don't  get this someday I get incredible battery backup and most of the days battery backup is 4.30 SOT. Does anyone facung same issue
Ehsank
Galaxy Note
did you check battery uses in device care, which app consuming more battery?
prakharg
Galaxy Note
No bro there is no such app
Ehsank
Galaxy Note
i mean to say that did you check which app on top in consuming on that day
prakharg
Galaxy Note
youtube and facebook
Ehsank
Galaxy Note
so you can do some settings for them which is not important for you check no.4 in my given settings hope this will work for you 😊
prakharg
Galaxy Note
sure brother let me try this. Just one question while charging your phone did you use your phone or not. If yes then have you noticed that your phone is getting charge fast or not.
Ehsank
Galaxy Note
if you use ur phone during charge, then charging time obviously increases, but how long increases it depends on what you r doing while on charge
Ehsank
Galaxy Note
btw if you want then can do these settings and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info(ibutton)>> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> Manage account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on weather settings (icon)> change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
KavUtk
Galaxy Note
The battery back up of Note 20 Ultra has taken a hit after upadtes. My phone runs exactly 12 hrs from 100% to 0% as I charge my phone only once a day.
But I am pretty satisfied as its performance hasn't taken a hit.👍👍
prakharg
Galaxy Note
after updated to one ui 3.1 did you reset?
