note 10plus battery
(Topic created on: 11-03-2019 02:04 PM)
sarfarazahmed
Galaxy Note
Pls share some tips to improve note 10plus battery
4 Comments
Parthh10
Galaxy Note
some recently downloaded 3rd party app must be the reason for battery drain.. go to device care in settings and put the apps to sleep which you think dont need background usage.. like Gmail, Whatsapp, Instagram, Snapchat.. these apps need background running or else you wont recieve any notification.. so dont put these apps to sleep.. but Travel apps like MMT, Goibibo, etc does not need background usage so put such apps to sleep.. This will improve your device performance and Battery drain.. also check the screen resolution.. downgrade the screen resolution when you are not watching videos or playing games..
Mannojj
Galaxy Note
if u have to downgrade screen resolution why spend 80k...
Parthh10
Galaxy Note
well for normal tasks like chatting, browsing, etc you cannot find out the difference between FHD+ and WQHD+.. its only when you watch videos or games you need WQHD+.. but turning on WQHD+ all the time eats up battery.. its just a trick to save battery.. you can keep it on all the time if you feel that you have spent 80k for that.. 😀
vicke
Galaxy Note
strict android system . it ll take lot juice from battery
