keypad problem in note8
(Topic created on: 04-29-2018 06:42 PM)
Kingsmaz
Galaxy Note
i always face keypad issue in note 8. i have done reset and also factory reset. always it hangs and unable to type bad65e30-3621-4f21-b3c0-b591b35394d1.jpg
5 Comments
jassi32
Galaxy Note
Try SwiftKey... It never lag in mine
Kingsmaz
Galaxy Note
how to get this. can u pls guide
Note10Plus
Galaxy Note
there is few lags in note
1) while tapping on editable field
2) searching on setting
3)expanding volume popup
4) tapping on notification
and may be others . these comes from Samsung's modified android. you cannot do anything about that .
jassi32
Galaxy Note
Download from playstore bro.... It works like charms I'm using it for like past 4 years
admin_
Galaxy Note
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
