edge lighting problem in note 9
(Topic created on: 02-02-2019 05:09 PM)
DineshManohar
Galaxy Note
My edge lighting notification is not working for Samsung message app when the screen is ON. It works for watsapp though. Anyone has a solution to this?
7 Comments
manthan6199
Galaxy Note
reset the phone and try
DineshManohar
Galaxy Note
already did.. still not working
Manglu
Galaxy Note
Google it up!
uk29
Galaxy Note
chk in d settings u myt have disable the edge lighting notification fr message
DineshManohar
Galaxy Note
its turned on for all apps..
kalkibhardwj
Galaxy Note
nice post
admin_
Galaxy Note
Thank you for sharing your concern. We apologize for the inconvenience caused to you. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback via Samsung member application i.e. Samsung member BETA app> BETA feedback>Send feedback>Error report>Collect log files>attach.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
