Resolved! Solved
battery usage not showing
(Topic created on: 01-02-2021 05:10 PM)
Not applicable
Galaxy Note
In note 20 ultra battery usage is not showing after 1st jan
Resolved!
24 Comments
madcow
Beginner Level 3
Galaxy Note
go to Setting->Apps
and there'll be the option to show system apps in the "filter and sort" symbol on the right
Not applicable
Galaxy Note
Yes, Lucky Ji Found it. Thanks for your help. I have cleared the cache and data both, now keeping my fingers crossed. I Will let you know.
Thanks for your help. Actually, this is my first Android Phone am new to Android.
LuckyRaj4442
Galaxy Note
kindly check screenshots
Galaxy Note
Bro, best way is to type samsung device health manager services in finder search..
Not applicable
Galaxy Note
I did that also but could not find it may be because show system apps was off . But anyway thanks a ton and it's good to know that there are people out there like you who keep on helping people
