Resolved! Solved
battery usage not showing
(Topic created on: 01-02-2021 05:10 PM)
Not applicable
Galaxy Note
In note 20 ultra battery usage is not showing after 1st jan
Resolved!
Not applicable
Galaxy Note
what steps did you try
LuckyRaj4442
Galaxy Note
Go to Settings - Apps - tap on Your apps... -turn on Show System apps- then Search for- Samaung device health manager service app- then clear cache as well as data.. n wait for few minutes/hr
Not applicable
Galaxy Note
there is no option of show system apps
madcow
Beginner Level 3
Galaxy Note
me, too. yayyy
LuckyRaj4442
Galaxy Note
if u can't find the app jst scroll down n search manually
Not applicable
Galaxy Note
there is no app by this name only device health
LuckyRaj4442
Galaxy Note
it is there .. some time it does feel like it's not there ... bt scroll down n make sure.. u have turn on system apps.. check my screenshot below
Not applicable
Galaxy Note
no it's not there in my note 20 ultra there is device health service and I cleared the data but issue is the same.but if I change the year to 2020 it shows the data and if I select the date to set automatically then the whole data disappears after some time
LuckyRaj4442
Galaxy Note
did u turn on System apps??
Not applicable
Galaxy Note
I didn't find system apps option ??? where can I enable it
