Resolved! Solved
battery drain..
(Topic created on: 08-04-2020 03:12 PM)
MIYU
Galaxy Note
#galaxynote10lite,#note10lite
Guys pls look into this battery drain issue. Need ur help to lessen it.
Regards
Pearl
Ehsank
Galaxy Note
all my settings will definitely work for you
if you like my comments then please accept as solution by clicking on 3dot at my comments
7 Comments
Ehsank
Galaxy Note
do these settings to save more battery life
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. developer option >background limit>no background processes.
5. Long press on each app specially 3rd party and rarely used app>app info>
6. Device care>battery >select "optimised and adaptive power saving.
Steps to enable developer option
settings >about phone>software information >then u find build number >tap 7 times>then back to settings
and at end of settings one new option called developer option
click on it and find that option
Ehsank
Galaxy Note
further go to battery check which app consuming more battery and set as no.5 option
Ehsank
Galaxy Note
and if you want to stop camera light sensors then you have to disable auto/adaptive brightness
as in Samsung using camera sensors for adaptive brightness
but after that u have to set everytime manually
MIYU
Galaxy Note
wow thanks
Ehsank
Galaxy Note
MIYU
Galaxy Note
thanks
Ehsank
Galaxy Note
thank you so much brother @MIYU
and one more thing always accept solution on specific comments with contain solution
like in my 1st and 2nd comments contains solution
thanks once again to accept my request
