Wifi Issue with Samsung Note 10 Plus
(Topic created on: 07-26-2020 12:11 PM)
ultral33t
Galaxy Note
Hi
Currently i am using Samsung Note 10 Plus which I bought in December 2019.
I am facing wifi disconnecting issues from past couple month. Whenever wifi is ON and connected - and later if i turn on Bluetooth or location then wifi disconnects automatically.
Spoke with support team and tried these things
1. Tried from safe mode
2. Resting network settings
3. Reset all settings
4. Factory reset phone.
Tried all things but same thing is happening. And wifi keep disconnecting. For better understanding i have recorded Video. Please do check.
Safe mode : https://youtu.be/GnUqEwU10xk
Normal mode : https://youtu.be/RI_ko380Wy8
Network reset : https://youtu.be/jLCDKClcXWg
All these video only people with above link can watch not meant for public.
23 Comments
chitti1998
Galaxy Note
once check with router also.
ultral33t
Galaxy Note
This video is recorded from Samsung S8 plus and this is also connected with same wifi network(router). And wifi issues with that s8 plus and also i have 3 more samsung devices under same wifi network(router).
I don't think this is router issue
ultral33t
Galaxy Note
as you requested. I have checked with different wifi network.
please check video
https://youtu.be/JCKMNrv1O8s
its still same. Wifi issue still happening.
chitti1998
Galaxy Note
you are getting the issue when bluetooth and location are on.
ultral33t
Galaxy Note
Yes. I have mentioned same in my post.
chitti1998
Galaxy Note
once check this in samsung members app> get help> interactive check > wifi and some other like bluetooth etc.. if there is no errors then take it to service center for better resolution.
chitti1998
Galaxy Note
ok then let's hope for the Note 10 plus user to reply regarding if they are also facing this type of issue. if so it's a bug.
vicke
Galaxy Note
no I don't have dis issue in my note 10 plus ...... I suggest to factory reset through recover mode ... orelse use smart switch to download complete firmware.....
ultral33t
Galaxy Note
done already.
