Spen battery issue.
(Topic created on: 06-07-2021 11:04 PM)
ankushaggarwal
Galaxy Note
Spen battery issue. Got low just after removing from the slot.
8 Comments
Galaxy Note
How long are you using your phone? Which device?
Galaxy Note
Mobile usage 5-6 hours per day and I use spen once or twice in a week.
Galaxy Note
Samsung note 10 plus
Prateek_
Galaxy Note
I'm having the same issue. Any solution?
Galaxy Note
Dude i had finding the issue on many website and observed that the issue is raising in many users after Mar-Apr 2021 update. May be the issue due to the software update. The issue may be resolved in next update.
Prateek_
Galaxy Note
Okay thanks for letting me know. I also did some research. Most of them are saying to replace it at the service center.
I'll wait for the next patch and if it doesn't fix it. I'll call my insurance provider to get it done. Hopefully it will be resolved.
AbhijithAshok
Galaxy Note
Situation of mine is entirely different.., s pen of my Note 10 doesn't drain even after multiple clicks or on standby.. but it takes min 15min to charge 100%..
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
We would request you to register your concern in Samsung Members Application. So, that our concern team gets back to you as soon as possible.
Please follow this path to register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Note. please attach the error log file within 15 minutes of the error occurred.
