Speed problem
(Topic created on: 10-29-2018 04:13 PM)
Kartik211
Galaxy Note
Sometimes my phone go very slow even after clearing the ram
5 Comments
Sushantnayak
Galaxy Note
Which are you using right now ??
Kartik211
Galaxy Note
Note 3
NishitMehta
Galaxy Note
Check App Using More Ram And Uninstall it
Check The Storage Space Delete Unwanted Particles Or Move To Memory Card & Keep More Space to the Phone Storage
And
Do The Following Steps
Setings》Device Maintenance 》App Issue Report》Click on App》Again Click on App》Uninstall
Do the Same With All App
And ReInstal Only From the Play Store or Galaxy Apps
This Will Solve Your Issue
And Keep Your Phone Updated
Galaxy Note
use your phone in safe mode once
PanPerfect
Galaxy Note
U check the mode. if power saving mode enabled. it will limit the CPU speed.
