Some questions before I replace some parts NOTE9
(Topic created on: 02-24-2023 07:12 PM)
lincon7
Galaxy Note
Hello! I'm planning on replacing the back glass cover, the battery, and the power button on my Note 9 later today. I have already acquired the parts I need but I have a few questions before I proceed.
For the battery, I was wondering if it is a good idea that I am currently trying to drain the battery fully before removing it or is it not necessary https://nox.tips/?
For the power button, I have already tried removing the button itself and pressing the contact using a sim tray remover. However, doing this does not activate the power button. I was wondering if the power button has a cable of sorts that may have been removed and I can just reconnect it or does this mean that I have to replace a whole module? I only bought replacement buttons.
3 Comments
Ab_Heartsy
Expert Level 3
Galaxy Note
Isn't it just safe to get it done in a repair shop🙄😑?
(I'm assuming you are trying it urself like a diy repair).
If you're really trying diy, try to find ifixit sources for this particular model or find similar videos on YouTube n try if you're okay with the risks involved.
cs-member11
Galaxy Note
Dear Samsung Member,
We acknowledge your query and apologize for the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
nanawawa123
Galaxy Note
Hi where did you get the battery from, Im in dire need of it as well
