Samsung note 20 ultra battery draining issue
(Topic created on: 10-23-2024 07:36 AM)
godgatdjfjajdj
Galaxy Note
How to fix this issue
5 Comments
Vikasofficial
Galaxy Note
Share a screenshot of your usage or sot time
Galaxy Note
goodthings
Galaxy Note
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy Note
Your's most welcome to here.
cs_member8
Galaxy Note
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
