Samsung Note 8 Slow Fast Charging Using Cable
(Topic created on: 10-18-2017 08:06 AM)
kamaraj
Galaxy Note
I bought My Note 8 Gold a week ago And i earlier used S7edge.
The issue i found is note 8's fast charging is comparitively slow than s7edge.
And having 3300mah on note 8 it should charge quickly than s7 edge which has 3600mah battery..
But on comparison note8 fast charging is slower than s7edge
so please fix this issue by providing a software update and anyone moved from s7edge to note8 will surely have noticed this issue
Note:- I am using the same charger and cable provided by samsung in the box.
8 Comments
admin_
Galaxy Note
"""Thank you for Joining Samsung community. We would recommend taking some troubleshooting steps to further isolate what you may be experiencing.
Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1116006
. Please let the community know what steps you have taken and if you have noticed any changes or improvements. This will help the Community to provide you steps without repeating any steps you may have already taken. ""
nitin4per
Galaxy Note
I am exactly experiencing the same issue...
original adapter and wire...
kamaraj
Galaxy Note
followed all those troubleshooting steps
but is of no use...
i did not notice any improvements
nitin4per
Galaxy Note
hello... Yes mine Note 8 also is heating up too much even just by playing a 5min YouTube video... Battery draining very very fast... Charging also very slow even in fast mode... worse than s7 edge ... Samsung team kindly help...
Darkoverlord
Galaxy Note
same issue here
kamaraj
Galaxy Note
being a flagship killer...
note 8 should outperform every flagships launched earlier.
This issue made me feel s7 edge is better than note 8
I believe a software update might help
otherwise i need to change my phone
nitin4per
Galaxy Note
Samsung team kindly reply...
3keshkurian
Galaxy Note
guys i dnt knw if dis will help.but i had d same issue.just blow really hard into the charging port.for me it worked.der mi8 b some dust or smethn stuck der.dat worked for me.gv it a try.
