Samsung Note 10+ Calling problem
(Topic created on: 04-26-2022 03:52 AM)
suhailze
Galaxy Note
My Samsung galaxy note 10+ is facing issues while placing a call it freezes for 3 to 5 seconds before I could place a call and it's not helpful in case of urgency
Anyone facing similar issue ?
2 Comments
Galaxy Note
Yes it is a software issue, I face this problem from direct call option
cs_member8
Galaxy Note
Dear Samsung member,
Check space availability:
Is there sufficient space available on your device?
Kindly check the space on your device:
Path: Settings > Device Care >Storage
To improve the device performance there should be sufficient space. Request you to keep at least a ''minimum 20% internal memory free''.
Kindly check RAM in your device:-
Path: Settings>Device care>Memory.
To improve the performance RAM of the device should be free. So, clear the RAM memory once a day.
Check app cache
Does the device hang while accessing any particular Application/Game etc?
Please follow the below steps
1- Clear app cache through Device care:
Step1: Navigate to the app's screen and tap on Settings.
Step2: Tap on Device care.
Step3: Tap on Storage.
Step4: Tap on CLEAN NOW.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Ask question).
Warm regard,
