Proximity sensor problem in Note 10 plus
(Topic created on: 05-27-2021 07:38 AM)
PradeepRP
Galaxy Note
When i received or i called after put hand or ear near screen its get off but wont woke up after the call or in the call. Only power key to get into screen. Anyone facing problems like this?
8 Comments
adi1990vyas
Galaxy Note
Are you using a screen protector? That is the cause... even i am having note 10 lite and same issue but once i remove the guard there is no issue in proximity sensing
PradeepRP
Galaxy Note
Yes i tried without screen protector. But same prblm
adi1990vyas
Galaxy Note
Then definitely needs a check .. try resetting the device once
PradeepRP
Galaxy Note
I check proximity sensor test also and reset and factory reset also bro. But still facing same problem
adi1990vyas
Galaxy Note
This is a known issue.. try downloading a proximity sensor test app and if its working, it could be problem with the call sensor, reset the settings and see if it works... also this could be caused due to any video calling app, try resetting those app as well
PradeepRP
Galaxy Note
Ok thank you. I will try
Agawron91
Beginner Level 3
Galaxy Note
did you solve the problem I have the same behavior and nothing helps
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
We would request you to register your concern in Samsung Members Application. So, that our concern team gets back to you as soon as possible.
Please follow this path to register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Note. please attach the error log file within 15 minutes of the error occurred.
