Problem with in display fingerprint
(Topic created on: 07-08-2022 10:53 PM)
ChoudharyG29
Galaxy Note
In display fingerprint in my note 10 lite is not responding to normal touch. I have to press it a little hard only thn it matches.
3 Comments
sangram21
Galaxy Note
U can remove all fingerprint IDs...and restart device,then add your fingerprint on light press,just normal touch.not to try hard press.
I think resolve ur problem.
If ur problem is slove then tell me...
Thank you😊
ChoudharyG29
Galaxy Note
I have tried all these but nothing has worked.
cs_member8
Galaxy Note
Dear Samsung Customer,
When you scan your fingerprints on the device, be aware of the following conditions that may affect the feature’s performance:
• The fingerprint recognition sensor recognizes fingerprints. Ensure that the fingerprint recognition sensor is not scratched or damaged by metal objects, such as coins, keys, and necklaces.
• The screen protector supplied with the device may cause the fingerprint recognition sensor to malfunction. Remove the screen protector to improve fingerprint sensitivity.
• Ensure that the fingerprint recognition area and your fingers are clean and dry.
• The device may not recognize fingerprints that are affected by wrinkles or scars.
• The device may not recognize fingerprints from small or thin fingers.
• If you bend your finger or use a fingertip, the device may not recognize your fingerprints. Make sure to cover the entire fingerprint recognition sensor with your finger.
• To improve recognition performance, register fingerprints of the hand used most often to perform tasks on the device.
• In dry environments, static electricity can build up in the device. Avoid using this feature in dry environments or before using the feature, discharge static electricity by touching a metal object.
Note: You should make sure to use the highest central parts of fingerprint or the most curved part of fingerprint when you register or scan fingerprint
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Thank you for writing to us.
Samsung Customer Support.
