Resolved! Solved
Problem with Headphone Mic
(Topic created on: 06-20-2020 12:30 AM)
Eerie
Beginner Level 4
Galaxy Note
I am unable to use my earphone mic for calls or online voice chatting. I have used different headphones and not luck. I also tried cleaning but nothing there either. I put my device in safe mode and still no use.
The problem is that the mic work on my note 8 but not on my Note9. Is there something wrong and can be solved?
When I record my voice using either video camera or the voice recorder app I can hear a faint static noise only. Please help if anyone has faced similar issues.
P.s All headphones are able to play music
Maps_sam07
Galaxy Note
Hi Eerie
Please reset the device settings an also perform a soft reset .
Please go to settings>> general management>> reset >> reset settings.
Please perform a soft reset of your device.
Press and hold the power and volume down buttons for about 10 seconds.
*The device may take a screenshot, however keep holding the buttons for a few more seconds.
3 Comments
Maps_sam07
Galaxy Note
Hi Eerie
Eerie
Beginner Level 4
Galaxy Note
I tried but I got nothing :(
Maps_sam07
Galaxy Note
Please take the device to the service center to have it assessed by a technician.
Please visit the link below to locate a service center near you :
https://www.samsung.com/za/support/service-centre/
