Note10+ fast cable charging not working
(Topic created on: 09-06-2019 11:06 PM)
Anik1991
Galaxy Note
Hello,
The fast cable charging option is not working even though the option is enabled .It was working earlier but after few updates it has stopped working. Its taking more time to charge.
Has anyone faced this issue ? If yes how was it resolved?
Thanks
7 Comments
anandverma
Galaxy Note
not yet
HasanElan
Galaxy Note
mine working fine still. have you tried with another fast charger? i mean another cable and fast charging adapter?
Anik1991
Galaxy Note
I have not tried it with another cable or adaptor. I will have to buy first as i was using type a charging cable before.
SamsungIN
Galaxy Note
You can try using another cable or charger
JaydeepMak
Beginner Level 5
Galaxy Note
same problem in s9 plus
Anik1991
Galaxy Note
HasanElan
Galaxy Note
i'd say collect another fast charger from someone (before buying a new one) and check whether the problem lies with charging cable/adapter or phone. in one of my previous note phones i faced similar issue and changing charging cable resolved it, but only worrying part is it happened in your case when the phone is almost new but mine was after using for quite a while.
