Note 9 Mobile Network Problems
(Topic created on: 02-02-2019 12:30 PM)
Hitarth
Galaxy Note
Note 9 Unable to Make Phone calls
Radio Network stops Frequently
Any Solutions ??
I had also tried to reset Calls &  Network settings, but didn't work
3 Comments
Not applicable
Galaxy Note
Try contacting samsung service centre.
admin_
Galaxy Note
Thank you for sharing your concern. We apologize for the inconvenience caused to you. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback via Samsung member application i.e. Samsung member BETA app> BETA feedback>Send feedback>Error report>Collect log files>attach.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Galaxy Note
already I visited Samsung service center two times but probably was not solved.
