Note 9 Battery Drain
(Topic created on: 03-24-2019 06:44 AM)
Miyasi
Galaxy Note
My new Note 9 after the last update goes through the batter really fast.. in the past i didn't have to charge the phone until the end of the day but now. When it mid day the battery is Atleast down to 25 perc. Then i would have to charge it again to go through the day. I need a way to fix this issue. Really bought this cause of the bigger battery if not i could have gone for the Cheaper and Easier to handle S9+
5 Comments
sgrkoirala
Galaxy Note
how much SOT are you getting?
Not applicable
Galaxy Note
Get your phone reset and then check it
Galaxy Note
1. disable auto brightness , adjust your screen brightness manually.
2. use simple black wallpaper on your lock screen and home screen.
3. disable auto sync
4. turn off all types of sound and haptic feedback like: keyboard sound, dialer sound, lock screen sound etc.
5. Turn off notifications for apps you do not use.
6. disable radios you do not use like NFC, BLUETOOTH, WIFI etc.
7. do not use live wallpapers or video wallpapers.
KrishanShamod
Galaxy Note
I have same problem....
Faxl
Galaxy Note
iam using note 8 same as my self getting very drained
