Note 8 sensor problem
(Topic created on: 02-11-2019 01:16 AM)
pk95
Galaxy Note
my note 8 iris, proximity & LDR sensor stopped working after January 2019 security patch update.need solution?
10 Comments
gakshat14
Galaxy Note
try to run hardware test by going into the boot me u
pk95
Galaxy Note
Thanks for the reply.But how to test hardware in boot menu? by dialing *#0*#?
Galaxy Note
SAME PROBLEM FOR ME
pk95
Galaxy Note
found any solution?
Galaxy Note
NO SOLUTON
gakshat14
Galaxy Note
Google how to get into boot menu
kartikcooll
Galaxy Note
sumudu76
Beginner Level 3
Galaxy Note
I'm having the same problem.... Samsung not helping us..
admin_
Galaxy Note
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
