Note 8 hanging problem
(Topic created on: 11-16-2017 03:58 PM)
sk619
Galaxy Note
why does the note 8 hangs and then crashes. it takes about 15-20 mins to restart even if I try to force start it with different button combinations.
there is some problem with the dialer because its the second time I had this issue in a month.
2 Comments
admin_
Galaxy Note
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
MSoHaiL
Galaxy Note
I have reported many times still to fix found. Most of the time i face with Facebook, Instagram and Samsung keyboard. They hang and at the end need to force close it.
