Note 8 gap between display and frame is it normal
(Topic created on: 09-29-2017 12:58 AM)
zafai
Galaxy Note
there is gap between display and frame of my galaxy note 8 I can see the light between the frame and display on both the sides of the display is it normal
7 Comments
vtzdude
Galaxy Note
change ur wallpaper bro
vtzdude
Galaxy Note
magic will happen and ur problem will go away
zafai
Galaxy Note
I have already done that .vtzdude
sarinbp
Galaxy Note
ya it's there. And when we view white background with full brightness we can see light leaking from those gap. every one facing this problem since galaxy s6 edge. I think it's common with all edge screen. according to Samsung glass is not directly glued with metal as metal will expand while heating so glass will break. So that little gap is design choice I think. how about the battery life u get.
Ichak
Galaxy Note
battery life is poor
admin_
Galaxy Note
We appreciate your inestimable suggestion. We have noted down your valuable feedback and we will surely share this with our relevant department, any update in this regards will be convey to you via various means of communication.
GalaxyTeam
Galaxy Note
Join Note 8 Telegram Group for Indian Users
https://t.me/joinchat/DvvVrkAYfNQcXiOLCes0vg
