Note 8 battery drain
(Topic created on: 09-08-2018 06:33 PM)
VanWilder
Galaxy Note
my Samsung Galaxy Note 8 battery drains from 15 to 0% quickly without using it within 5 to 10 minutes
5 Comments
sarinbp
Galaxy Note
try to reset the settings
VanWilder
Galaxy Note
settings or factory reset? and what kind of settings are you talking about?
sarinbp
Galaxy Note
there are two reset option first one settings only other factory reset. reset settings only.
PanPerfect
Galaxy Note
u must using WQHD display setting mode. reduce to FHD then u ll get proper backup
admin_
Galaxy Note
We do apologize for the inconvenience caused. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
