Note 8 battery drain
(Topic created on: 08-22-2018 09:12 PM)
BlackBlade
Galaxy Note
Hi Samsung can you please fix the battery drain with a good update. I love this device.. but the battery is not even withstanding half a day. I have now reduced the screen resolution to full hd+. still nothing great.
6 Comments
Rocky4111992
Galaxy Note
why you buy that device
BlackBlade
Galaxy Note
I brought it a year back
Sushantnayak
Galaxy Note
@rocky4111992 are there any issues ??
Sushantnayak
Galaxy Note
@blackblade rest assured you will get a reply from Samsung customer care and resolution also . And for the time being use full hd resolution ,switch off smart stay and if you want switch off always on display too.
I hope it helps.
559XG
Galaxy Note
try go to settings/device maintenance/battery/add app in always sleep apps 2b76c1d9-d7d5-4de5-8451-d12781a943d6.jpg
admin_
Galaxy Note
Thank you for Joining Samsung community. We would recommend you to follow some troubleshooting steps in order to further isolate what you may be experiencing in your device. Find the troubleshooting steps on the provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let us know what steps you have taken and if you have noticed any changes or improvements as this will help the Community to provide you further troubleshooting steps without repeating any procedure which you may have already followed. Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
