Note 20 finger print sensor issue
(Topic created on: 11-21-2021 02:40 PM)
NancySharma
Galaxy Note
Is anyone else facing finger print sensor issue on Note 20 ? In my case it fails 3 out of 5 times to regognize the finger print, will software update regarding this help ?
9 Comments
Not applicable
Galaxy Note
Are you using screen protector
NancySharma
Galaxy Note
Yes
Not applicable
Galaxy Note
May be because of that remove and try
And re -register your fingerprint
Souravds55
Galaxy Note
Try Turn on touch sensitivity
NancySharma
Galaxy Note
I have already tried this .
Galaxy Note
Seems like the issue caused my screen protector.
Not all screen protectors are good with underdisplay fingerprint scanners.
So try without screen protector.
Randy_Lahey
Galaxy Note
Yes, I used many screen protectors but there was an issue with the display touch sensor, so my friend recommended me Gadgetshieldz screen protector for me and I installed it with liquid as they provide in the pack. Now I don't have any fingerprint sensor issues or touch issues because it sticks well to the display.
Astrobeast
Galaxy Note
I got same problem in note 10 but not because of software or hardware issue. The problem occurs to me because my thumb finger skin is peel out and skin drying due to winter that why my phone is unable to recognizing my fingerprint.
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung member,
Thank you for sharing your concern. And please follow the easy troubleshooting steps which might help to solve the issue.
Check if your finger has any liquid or dirt. ...
Clean the fingerprint module. ...
Check if the fingerprint module is well connected. ...
Restart your device. ...
Update your software. ...
Wipe System cache. ...
Recalibrate the fingerprint. ...
Reset your device.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
