Note 10+ wifi connectivity issue
(Topic created on: 05-12-2020 04:50 PM)
ShashankSingh21
Galaxy Note
Hi All,
My Note 10+ keeps disconnecting. It will run on wifi for 5-10 mins then go into limited connectivity mode. And will connect again on its own after 3-4 mins. However if I switch off wifi on my mobile and turn it back on it connects instantaneously.  So definitely its not the router's problem. I am super irritated due to continuously toggling between off/on for wifi button on notification panel. Is anyone else facing similar issue or its just me. :(
My wife's OnePlus works just super, it is connected all the time to wifi. My old Xiaomi used to work splendid and never had any issue with home wifi. But with this Note 10+ it has become a headache. Feel cheated after spending so much on a dumb product which can't even perform basic functions.
12 Comments
gauravnift
Galaxy Note
A new update will be pushed for samsung members soon.
read somewhere on #xdadeveloper
thank you
#india
ABHISHRIDHAR
Galaxy Note
just turn off the s pen air actions, wifi connectivity issues will resolve. plz share your experience with this fix
atan765
Galaxy Note
Seem like my Note 9 has the same problem happened after update of software on 28 Septrmber 2020.  I believed that some driver software inside the update triggered this problem. Your Note10+ use the same driver.
