Note 10 plus echo problem
(Topic created on: 02-07-2025 08:04 PM)
FaisalAhmad
Galaxy Note
Suddenly I found echo problem in my phone when talking to other also recording is not perfect.
3 Comments
arec
Galaxy Note
What's problem brother!
FaisalAhmad
Galaxy Note
When auto recycling is on I found echo in the same
cs_member10
Galaxy Note
Dear Samsung Member,
● Disconnect all accessories: Disconnect anything plugged into the headphone jack like, a selfie stick, headphone, Bluetooth, etc.
● Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
● Restart the device: Press & hold the power key>Tap on Restart>Tap again to Restart your phone.
● Record your voice without using headphones by using a voice recorder" and playing the recorded audio:
Step 1: Navigate to the apps screen and tap on the Samsung folder.
Step 2:Tap on Voice Recorder.
Step 3: Tap on recording to record your voice then tap on Stop to save the recording.
Step 4: Tap on Save.
Step 5: Select and tap on recently recorded audio to hear the audio quality.
Note: If the recorded audio quality is good, then your microphone is working fine.
In case the issue still occurs please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
