Network issue auto reject calls (incoming&outgoing)
(Topic created on: 09-29-2021 05:10 PM)
pazhanivelrajan
Galaxy Note
All incoming and outgoing calls are auto rejected or auto disconnected by mobile device. I can't use this device for making calls or receiving calls. Please resolve my problem with the next security patch update as soon as possible.still This problem continues when I bought this mobile. So please take care of this problem.
Mobile : Samsung galaxy note 10+ 5G
Model no : SM-N976N
Akshay02
Galaxy Note
Try putting it only 3g mode if you have network issues.
Galaxy Note
Ok let's try ...but while using internet 3g speed only I get. That's why I thinking to other solution
Akshay02
Galaxy Note
Try this when you are calling
Galaxy Note
Let's try this
Abpal
Galaxy Note
Contact network provider, they will surely help you about this.
Galaxy Note
Airtel customer care told ,they have no problem with this Sim. So only I try to contact samsung customer care.
Galaxy Note
gouravsama
Galaxy Note
Ssme problem from last five months on my note 10+ sm-n975f
Galaxy Note
I am also tryto resolve...it . But can't.
imf1614
Galaxy Note
Remove sim tray.. clean the golden chip part.. insert carefully.. fixed my issue
