Incoming Calls Not audible In Note 20 Ultra at times
(Topic created on: 12-24-2020 09:15 PM)
karan0308
Galaxy Note
The issues from Beta is still there in Official update of Note 20 ultra One UI  3.0 . I am not able to hear incoming calls at times. It's always a hit or miss.This bug started from beta software and is still there after the official software update. Really Irritating.  Is there anybody else also facing some similar problems?
3 Comments
NoteFun
Galaxy Note
please do hard reset by pressing volume down and power button, then select option erase catche file...It might solve ur problem...
Galaxy Note
facing problem in WhatsApp massanger
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
We are sorry for the inconvenience caused to you. We request you to kindly send us the error log file along with the Video or Screen-shots within 15 minutes of issue occurrence through error report section from Samsung Member Application:- Samsung member > Click on beta banner > Switch to beta mode > Beta feedback > Send feedback > Error report. As this will help us to further investigate and resolve your concern.
