I'm using samsung galaxy note 10 plus. It is showing battery issue detected
(Topic created on: 04-14-2024 12:52 PM)
UmairIbniShowkat
Galaxy Note
My note 10 plus showing battery issue is detected even after changing it's battery and restoring to factory settings. Still problem not resolved. Any expert help me in this regard.
2 Comments
Bhava003
Galaxy Note
Go to Service center & replace battery. Problem solved.
cs_member10
Galaxy Note
Dear Samsung Member,
As per your query, we request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
