How to improve speed of Fingerprint and Face unlock in Note 10 lite
(Topic created on: 03-31-2020 11:45 PM)
tanwanimohit
Galaxy Note
Hello guys,
I am going to share a simple trick to improve the speed of fingerprint and faceunlock in galaxy note 10 lite.
So first of all, make sure that you have correctly registered your fingerprint, as i have many poeple doesnt cover their fingerprint completely while registering thats why their fingerprint doesn't match everytime. (Tip: Add your fingerprint multi times)
Let's start with the main trick...
1. Goto settings.
2. Search of "Optimise battery usage"
3. Click the first result and open the category "Optimise battery usage"
4. Now click on "All" in select menu from top
5. Now search "com.samsung.android.biometric"
6. And you will find one result just untick that app.
That's it  Now you will see significant speed improvement
Thank you.
17 Comments
dLcreations
Galaxy Note
No significant improvement. Share some robust solution mate !
Not applicable
Galaxy Note
exactly even on note 10 plus of mine is not working well even after this optimisation is turned off
hedgehog
Galaxy Note
maybe some tweaks in your note 10 plus are still needed because I use note 10 plus too and have had no problem with biometrics till date from 9 months usage👍
hedgehog
Galaxy Note
dLcreations
Galaxy Note
@mapledew - There is no problem Its just slow. I will check your link
hedgehog
Galaxy Note
go to apps in settings and click on 3dot on upper right corner click special access go to optimise battery its 1st option
Not applicable
Galaxy Note
not much effect
hedgehog
Galaxy Note
you try
RushabhShah
Galaxy Note
can we find similar thing on A70s?
