How to Fix Galaxy Note 10 Fingerprint Scanner Problems?
(Topic created on: 07-07-2022 04:39 PM)
riddhis5
Galaxy Note
   Hi, I am Owais from Sanjay Metal India.
   I have a problem with the fingerprint scanner in my phone . let me know how to fix it?
2 Comments
Galaxious
Galaxy Note
cs_member8
Galaxy Note
Dear Samsung Customer,
When you scan your fingerprints on the device, be aware of the following conditions that may affect the feature’s performance:
• The fingerprint recognition sensor recognizes fingerprints. Ensure that the fingerprint recognition sensor is not scratched or damaged by metal objects, such as coins, keys, and necklaces.
• The screen protector supplied with the device may cause the fingerprint recognition sensor to malfunction. Remove the screen protector to improve fingerprint sensitivity.
• Ensure that the fingerprint recognition area and your fingers are clean and dry.
• The device may not recognize fingerprints that are affected by wrinkles or scars.
• The device may not recognize fingerprints from small or thin fingers.
• If you bend your finger or use a fingertip, the device may not recognize your fingerprints. Make sure to cover the entire fingerprint recognition sensor with your finger.
• To improve recognition performance, register fingerprints of the hand used most often to perform tasks on the device.
• In dry environments, static electricity can build up in the device. Avoid using this feature in dry environments or before using the feature, discharge static electricity by touching a metal object.
Note: You should make sure to use the highest central parts of fingerprint or the most curved part of fingerprint when you register or scan fingerprint
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Thank you for writing to us.
Samsung Customer Support.
