Resolved! Solved
Help regarding note 10 keyboard issue .
(Topic created on: 05-17-2020 01:30 AM)
sha31nk10
Galaxy Note
Hi, all  need help I'm using note 10 my keyboard is getting stuck and feeling very jerkey and is causing  difficulty in using the device kindly help . I'm facing this problem from last 2-3 days .
Thank you
Galaxy Note
Bro, click 3 dots and accept it as solution(my 1st comment)
4 Comments
GreenNoid
Galaxy Note
update to the latest version in ApkMirror, just search Samsung Honey Board
mudassarfa
Galaxy Note
use gboard. Google keyboard it's faster than Samsung keyboard
Galaxy Note
Just, check for recent keyboard update, released day before yesterday
or
reset keyboard to default settings and try again
or
last option
settings>applications>scroll down to Samsung keyboard>select it>click 3 dots at top right corner>uninstall latest updates
Galaxy Note
