Galaxy Note 10 Battery discharge issue after 45days of usage
(Topic created on: 11-06-2019 06:02 PM)
Dhritiman_Das
Galaxy Note
Even after 45days Galaxy Note10 battery discharges faster than expected while I keep my sync On and GPS on for clicking photos and navigation. I think battery life can be improved with a software update but it seems Samsung is not listening to users of Note10.
I still love my Note10. Samsung please fix it ASAP.
Dhritiman_Das
Galaxy Note
let me try and come back to U
Balu332
Galaxy Note
How many hours sot you are getting bro?
Dhritiman_Das
Galaxy Note
where to see SOT?
Balu332
Galaxy Note
Dhritiman_Das
Galaxy Note
hmm but under battery usage there no Screen option 😔
Balu332
Galaxy Note
Bro click on the 3 dots in right hand side in battery usage and check whether os apps hidden or visible
Dhritiman_Das
Galaxy Note
ok i got it..it shows SOT as 47mins
Dhritiman_Das
Galaxy Note
this is the one☝️
Balu332
Galaxy Note
Check it from 100% battery to 15% battery and see the total sot. if it is less than 4 hours than you were having an issue.
Dhritiman_Das
Galaxy Note
ok..got u
