Bug: Note 9, using Spen Navigation bar doesn't work
(Topic created on: 12-23-2019 06:36 PM)
NuClr
Galaxy Note
Dear folks,
I think in Beta 4, using Spen the back and navigation opening is not working, seems this s/w portion is broken.
Kindly click it out, if it is working in your's
5 Comments
Ajverma
Galaxy Note
You have to enable gesture with spen in settings
NuClr
Galaxy Note
My bad, didn't get that@ first, Thank you bro.🙏
NuClr
Galaxy Note
will keep this post, in case someone Ignorant like me can see my ignorance.
NuClr
Galaxy Note
Haha, don't get scared bro, this is not a bug Courtesy Ajverma, my ignorance was bliss,
Samsung_Support6
Galaxy Note
Hi there,
Please follow the below mentioned step in order to resolve the issue:-
>Please disable the S pen gesture (Go to settings>>navigation bar>>block gesture with S pen>>disable it).
>Please reset the S pen once and check the issue (Insert the S Pen into the slot>>settings>>S Pen>> open the Air actions>>Tap on top three dots on right corner>>reset S pen).
For further assistance, register your concern in the Samsung members app (Open Samsung members app>click on “+“icon>send feedback>Error report/ Ask Questions).
Regards,
Samsung Members Team
