Battery drain in note 9
(Topic created on: 01-17-2019 09:19 PM)
shreesha
Galaxy Note
Is it just me or there is an unexplained battery drain in note 9 after the pie update?
13 Comments
Harsh18750
Galaxy Note
poor battery backup
Hamidk
Galaxy Note
yes... me too facing battery back up issue.
Thuwa
Galaxy Note
ya same problem other than that no issues perfect update
Azzu55
Galaxy Note
Are you getting edge lightings in Samsung music app which we use to get earlier in oreo?
Lauki
Galaxy Note
No edge lighting in Music app. This is weird!
advait92
Galaxy Note
I have the same problem. The battery drains too quickly.
UrsSBA
Galaxy Note
if u are all getting fast battery draining issues just factory reset
iam getting 5-6 hr STO after factory reset
Hamidk
Galaxy Note
factory reset is not feasible as most of us will be having lots of data stored on phone and taking a backup will be time consuming...
sulembhai
Galaxy Note
yah but thats the last thing i wanna do bcz its just a pain to reset and add the data again.. youtube perticulary eats up the most battery..optimization needed bcz pie and one ui are supposed to be more optimized and light and with the addition of adaptive battery...battey drain should be the last issue one ui should face
