Battery Life Problem
(Topic created on: 01-26-2019 08:01 AM)
KrishanShamod
Galaxy Note
I bought a Note 9 brand new on 2019.01.23  and I updated it to android 9 but now I feel note 9 battery life is very low(I got 5 hour screen on time).Is it normal?? Is it fix in several days because my one is brand new ???
9 Comments
nitkr
Galaxy Note
I too faced the same problem. but I did a factory reset and things are normal again..
did you try resetting??
KrishanShamod
Galaxy Note
no.I update my note to android pie.
RHINOCHOPPER
Galaxy Note
guys after updating to pie my note 9's 4g network is not working properly it is working only when it has full signal strength and it is not working when it has less than full signal
TBT
Galaxy Note
We have 2 Note 9 in our house. One is functioning superb, maintaining the all day battery along with 6+ sot, but another one always had 5 sot average, which i think isn't normal
so I reset the 5sot 1 to check if any improvement, now waiting g for actual results how it performs
I still feel the note 9 battery drain issue is a little noticeable
Thuwa
Galaxy Note
i guss it's normal i am also getting 5hr of usage time
arend
Galaxy Note
guys any one dont want galaxy watch offer plz send help me get that I just buyed before and offer
KrishanShamod
Galaxy Note
can we report this to Samsung and get update for it???
manthan6199
Galaxy Note
it may be just software issue...just wait for stable pie update amd your problem should be sloved
admin_
Galaxy Note
Thank you for being a part of Samsung community. We apologize for the inconvenience you are facing issue in the device after the update. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback via Samsung member application i.e. Samsung member BETA app> BETA feedback>Send feedback>Error report>Collect log files>attach.
Be sure to hit ♡ when you find an answer that works for you.For Further assistance, you can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
