Battery Drain
(Topic created on: 10-15-2021 12:35 PM)
KavUtk
Galaxy Note
Dear Samsung,
I am facing a major battery drain issue on my Note 20 Ultra device.
How to resolve this issue ??
6 Comments
UserAdik
Galaxy Note
Indian Version Variant only! I don't know do you get or if you have October 1st security patch it should fix the problem because I am using M30 sum are using M31, M30 and A series phone and the update is much better there is battery drain but it has reduced and no heating if you are having heating issues as well also there might be some new features! Or it might Ulta for you! Ulta means bad things will happen in this Update!
KavUtk
Galaxy Note
Yes, I am using Indian Version of Note 20 Ultra and I have not received the October security patch. So, waiting for it.
UserAdik
Galaxy Note
Yes please wait
AlphaTrion
Galaxy Note
Note 20 Ultra uses Exynos 990. Samsung's worst flagship processor.
Its known for terrible sustained performance, and terrible battery backup.
Each updates will only make it worse.
Cannot be fixed beyond a certain limit.
Shammy4
Galaxy Note
Samsung suxkynos 990 S.U.C.K.S. SAMSUNG should compensate all note 20 ultra owners
Galaxy Note
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
